prv
on a small boat the cradle will fall over or slide about
I would not recommend a cradle. Firstly on a small boat the cradle will fall over or slide about
secondly if the radio moves in the cradle it can disconnect the power so not be charging when you expect it to.
With a cable & plug you can wedge the radio in a safe place & forget
Screw to a safe place and the cradle for the 851e has retaining parts that hold the hold radio in place. can hold the cradle upside down and radio stays in.
Edit - beaten by Pete
Agh... beaten by both of you. You can even blue-tak it to a horizontal surface - I know because my 11 yr old grand-daughter fixed like this when we first got it.
The memory effect of Ni-Cads is what makes totally inferior to modern rechargeables.
Thanks for all the input. While I would really like to go for a DSC/GPS handheld I think that will be prohibitively expensive for this trip. A fixed DSC radio appears a bit cheaper? And greater range appeals. What sort of battery draw could I expect? I just have a single 60A car battery at the moment, running the sounder, mobile charging an possibly nav lights.
Someone did mention that its possible to extend the antenna on a handheld? Or connect it to a masthead aerial?
Doubt you'll get a fixed DSC that much cheaper. Cheapest DSc VHF I have seen is about £90 -£95. I assume that you don't have existing masthead aerial so about £40-£50 for that. Then will need some cable maybe £10 for the coax. I'll assume that you have the cable for connecting to battery as would be similar to HH
Then have to install it all and connect to a standalone GPS ensuring that they you can get the NMEA to talk to each other.
You might save a couple of quid over the £160 that an 851 will cost and the fixed will be a better system but will not be able to move to your kayak.
Hmm. True. I've not still not found an 851 for under £200 though!
Link I gave you in #4 has them at £159. Bought one from them earlier this week.
The better Cobra handhelds at £80+ are perfectly good radios:
