Handbearing compass
LONG_KEELER
21 Jul 2009
East Coast
Will not work.
Not sure if this is true but I am told that there are 2 styles of binos. Asian & european. Asians have the lenses closer together as their eyes are closer together than europeans ( that is not being racist or anything it is an observed fact)
Europeans need binos with a wider viewing space between the 2 parts. I was given the binos as a prezzie & to use them I have to have them at maxm width. Made in Japan. This tilts the compass at 45 degrees to the horizontal. So that means that I have to tilt the binoculars & look through 1 lens with the other over my forehead.
Might be handy to have a third eye, but then I would have to stick the other lens up my bum. o_O
So putting my head on gimbals would not work as the compass would always be at 45 degrees to my eye
I have a 7x50 Russian monocular which is literally a binocular sawn in half. It's still quite effective but rather heavy. You still need one really good eye though.
I
johnalison
14 Feb 2007
Essex
While I agree that a hand held compass should be carried as a backup navigational instrument, the emphasis on collision avoidance seems wrong to me. It's too insensitive for that; I line up the target with objects on the boat, which I find much more sensitive. The very best hand bearing compass used from the unsteady platform of a boat is going to be accurate to a degree or so; my eye with appropriate sighting lines is much more accurate. The moon is half a degree across; it's easy to see angular changes much less than the width of the moon. The eye is a very accurate estimator of angles; it only lacks an absolute reference. Remedy that with sighting lines, and it's much more sensitive than a compass.
You’re doing well if you can take a bearing to anything like one degree from a small boat at sea. I can, in calm conditions, but this never happens when I actually need an accurate bearing. I’m not sure that sighting across the boat is very reliable, unless your autopilot is a lot better than mine, though I do it as a rough guide of course. I have always found that a change in an approaching vessel’s aspect is a better guide to the collision risk than its bearing, even if AIS has largely obviated the need for this skill.
awol
4 Jan 2005
Me - Edinburgh; Boat - in the west
Will not work.
Try using them upside down and tilt your head?
Daydream believer
6 Oct 2012
Southminster, essex
Then I would be going ,when I should be coming. :unsure: I doubt that will work but I will try it when I get to my boat. The first problem will be the head tilt, when the body is already trying to accomodate a boat that may be heeling over. Then as I said, the binos do not open wide enough, so that is an issue.
