Darran1967
TOP TIP!!!
I have posted threads on here before saying that I find it impossible to hand start a Yanmar GM10, well i`ve now cracked the problem.
I went down to my boat yesterday and found that I had left the 12v supply switched on, this has lead to a completely flat battery.
In order to start the engine, I had three choices, either get the battery from the car, put the battery on charge from the shore power charger or hand start it. Having had no success at hand starting in the past, I thought I was on a hiding to nothing but I still gave it a go.
Keeping the compression off, I started winding up the engine....no problem getting it turning to a decent speed, then on with the compression........yup......stopped dead. I tried again, this time releasing the compression button slowly and guess what........yup......stopped dead.
At this point I was about to give up, then I had an idea to start it like a motorbike.....use a kickstart!!!
I turned the engine until the cranking handle was at about 5 to the hour (if you know what I mean), then I put my foot on the crank handle and pushed down hard to crank the engine over. I did this twice, then on the third go it started. I was pleased as punch with myself.
Let me know if any of you have the same success. It is worth trying to start with the hand crank as you never know when you`re going to need it whilst out at sea.
