Spyro
Are you 6'10", and built like Arnold?
If not, forget it and carry a spare battery.
Spare battery is not much use if it's your starter motor that's gone.
I heard of a singlehander doing similar, but with the rope attached to the boom. He gybed all-standing to pull-start the engine.
It's also worth remembering that if your batteries are low, but not totally flat, it's often possible to start a decompressed engine on the starter motor.
As an ex boatbuilder I do take exception to that comment...
Have you ever tried fitting an engine, in a yacht??
Spyro correct, but if you have any battery power left - though not enough to actually start it, giving a go on the starter as well midway through the spinning it up phase greatly eases the backache. This may mean that you need three hands at least.This query might apply to most (all?) engines, but just in case this one has any peculiar habits I reference it. I was wondering what the proper procedure is to hand crank this engine?
I have found the unused (by me) handle and I thought it might be a good idea to know how to use it!
I know I have to do something with the de-compressors, but which one (s), all of them, one at a time? etc
Any words of advise/cautionary tales of woe?
Cheers all.
? It's a diesel.Don't forget to turn the ignition on
? It's a diesel.
Indeed. All you'll achieve by turning on the electrics is annoying yourself with the buzzer (unless like me you have fitted a silencing switch).
A handful of diesels have solenoids on stop controls etc that need to be on to run (rather more have solenoids that need power to stop) but as far as I know that's not the case with any GM series engine.
Running many diesels with the "ignition" turned off puts the charging circuit under stress and can blow components.
Almost took my thumb off first time, I thought the handles were ment to disengage? Mine doesn't :S
I always start my 1gm10 by the handle if it hasn't been used for a few weeks, I feel it's better for the engine.
I got the knack of pulling the handle out before my hand gets taken off.
I'm not an expert, but I can't see why that would be. If you know why, in all seriousness please do educate me. Otherwise, are you sure you're not confusing it with disconnecting the batteries with (eg) a 1-2-both switch?
I did say some engines - our new Jeanneau (with Yanmar 3gm20) has dire warnings in the user manual to stop the engine with the "stop" button before turning off the electrical system with the "off" button - the "ignition" key - in reality the "on"/"off" button seems to control relays that isolate the charging circuit from the battery in much the same way as the older "1-2-both" switch - which we do not have...
Why bother? Do you use a starting handle on your car? No - it wont even take one because the starter motor is so reliable.
Just equip the boat with a decent engine only battery and throw the handle in the bin.
Staring handles! Pah! next thing you'll be using sextants, galvanised rigging, gaff rig, wooden hulls and baggy wrinckle. And walking down the pontoon wearing sea boots and with a nicely judged roll. Ahoy there me hearties.![]()
