Hammerite "rust beater"
TiggerToo
23 Aug 2005
UK
Does it "go off"?
I have a tin which is a few years old. The solids have sedimented, but it is still workable, and the solids can be gotten back into suspension after some patient stirring.
Will it still work to "convert" rust?
That is probably what I will do, but I am curious nevertheless.
Does anyone KNOW whether there is a "shelf life" to the rust-beating chemistry, as opposed to the "paint chemistry"?
BTW of all the rust treatments I applied to my cast iron keels over the years I found Hammerite No1 Rust Beater the most effective.
The manufacturer should give a shelf life/open time on their data sheet. Life may reduced depending on storage conditions.
Does it "go off"?
I've just used some from a tin which I bought in 1989, when it was still "Finnegan's No. 1". It needed a good old stir to get it to the usual consistency, but looked, smelt and felt just as it should.
Two years unopened. And it's not for use underwater, by the way. See attached.
It may be relevant that the paint chemistry has clearly changed a lot. Hammerite thinners are now white spirit whereas they used to be xylene based and neither will work the wrong way round. Luckily International Thinners No. 3 (the stuff for antifouling) are also xylene based and work fairly well with old Hammerite products.
... And it's not for use underwater, by the way. ...
I overcoated it with Primocon before antifouling and experienced no probs. When I stripped my keels last year using a Tercoo rotary blaster the No1 Rustbeater took a lot of shifting. It seemed to have bonded itself and the underlying rust hard onto the base metal.
I always use Acetone for thinning Hammerite.
