Halmatic 30 Keel Bolts cast iron keel?
charliedees
2 Jan 2025
A Halmatic 30 has come up my way for sale. The only thing that concerns me is the external cast iron keel and its keel bolts.
Is there generally any issues with the Halmatic 30 keel bolts and is replacement a easy enough task? The Quotes that I have received for replacement and keel removal makes it an expensive exercise.
For the price of the Halmatic 30 and having to figure in keel bolt upgrade a more modern design would become more realistic.
charliedees
2 Jan 2025
Upon survey when it was hauled after drying there seemed to be some rust stains near the keel ballast joint according to the surveyor. There was no visible gaps or looseness. It could just be rust from the cast iron keel and nothing more, however how can you really tell.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Inspect and lightly abrade the studs/nuts in the bilge. Look for rust staining around them but don't be misled by rusting of the washers, which will almost certainly be mild steel. It is rarely necessary to replace stainless steel keel bolts.
If the seal fails between the keel, bolts and hull there will usually be considerable rust in the bilge as water drives it into the boat.
charliedees
2 Jan 2025
Thanks for the advice. I dont think the keelbolts are stainless, I suspect that they are galvanised steel. However I could be wrong and the owner is not fully familiar with the specifications. I will do some more checking and also see what the surveyor thinks. Again thanks.
donm
17 Jul 2005
Bristol Channel
When I bought my Halmatic 20 years ago it had some small rust streaks along the keel joint so I cleaned them up and replaced a small bit of joint after cleaning the keel to bare metal, treating and painting. 20 Years later no problems. Apart from disturbing the bolts and joint needlessly, the bolts, 9 of them, are all the way through and will need removal of tanks and engine!
I have the design drawings and they show inch and a quarter stainless steel. They are very well built boats
charliedees
2 Jan 2025
Well with those size keelbolts and no history of issues with the keel bolts it may be a none issue. I will ask the surveyor to complete the survey and I can then proceed with the negotiations and offer. Thanks for the advice.
donm
17 Jul 2005
Bristol Channel
Re-reading my post I may have given the impression that the bolts go through the keel whereas I meant that they are along the full length of the keel and will require removing everything in the way. I believe that they are studs. I look at the ones that I can see each annual lay up and they have always looked fine.
Good boat that sails well and is a very comfortable sea boat. Don’t figure on being able to steer astern though as the choice is the boats’ and not yours!
charliedees
2 Jan 2025
I am down sizing with age and 30ft, 9ft of beam and a long keel is about right for me. My sailing is typically the milk run into the Pacific, I am not mariner hopping or doing the Med shuffle so struggling going astern is not really going to bother me traditional suits me fine.
charliedees
2 Jan 2025
Yeah, the owners of Halmatic 30's know the reputation of these boats and hence are very tough when it comes to price negotiations. Unfortunately the realities of insurance, rig inspections, hull and engine all has to be factored in well ahead of the boats reputation and a compromise reached. Not all sellers are realistic.
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
Be sure to have a good look at the chain plate attachments too. Most will have been modified by now but early ones were inadequate, leading to deck cracking. Otherwise, great boats.
Cotillion
30 Aug 2003
Walton on the Naze
Going astern, the stern will demand the wind and there is nothing you can do to change its mind. Add in prop wash (usually to port with a modern engine) and it becomes predictable but frustrating. Leaving a marina berth often takes an amount of warping.
donm
17 Jul 2005
Bristol Channel
I have a fore and aft mooring alongside a row of boats abeam and don't have a problem. Even when berthing between boats or on marina pontoons, judicious use of the prop wash to turn the boat keeps me out of trouble. The trick is to always think about leaving before berthing, so that you arrange it such that you won't need to go astern!
And the payback is that in all other respects the boat does everything else that you would want and expect, and in spades!
Slowboater33
25 Feb 2023
I have a barbican 30 (modified Halmatic) and it's pot luck going astern. Usually on a mooring,been practising going astern and I doubt I'll ever master it 🥴
