mrming
Just bought 50m of 12mm Liros 3 strand nylon spliced to 10m of 8mm chain from Jimmy Green.
The windlass is a Quick Genius with a combination rode / chain gypsy.
Unfortunately when the rode falls through the gypsy it bunches up and gets stuck. The rode is pretty soft and this has immediately damaged it.
The rode had a lot of twists in so the first thing I did was spend a long time working those through. This unfortunately doesn’t help. Currently the only way I can get it to go through the gypsy is to keep it under tension. Unfortunately this is not workable as it needs to be able to fall into the chain locker. The chain goes through no problem.
I didn’t buy octoplait because the quick website only said 3 strand would work.
Rode + chain is preferable as the chain lives right in the bow of the boat and I don’t want a ton of weight in there.
Any pointers as to where I have gone wrong? Is there a stiffer type of rode for example?
I have a feeling I have just purchased £150 worth of rode I can’t use.
