Dull Spark
I change the engine coolant and use OAT as per the previous owner, so no change of type or manufacturer of coolant. I still get deposits of gunge in the system, visible on the rubber seal around the pressure cap. No real issue, but last year the gunge blocked the overflow pipe and needed to be removed with a small cable tie. My concern is for any tight clearances in engine cooling channels. Am I worrying over nothing or should I install an in-line strainer on the line to the calorifier? The heat exchanger has copper-based alloys as, I'm sure has the calorifier. Is OAT the right stuff?
