GRP and epoxy question
damo
22 Feb 2005
k keeper,Portishead
longkeel35.org.uk
I am making some components out of polyester resin and CSM (cos I have it in stock), and want to attach them to an existing grp structure with epoxy and woven roving
How long would I have to leave the new grp before using the epoxy?
Ta, I'll probably do that then /forums/images/graemlins/smile.gif
But do you happen to know long before the polyester has cured enough that epoxy would bond to it adequately?
The epoxy will bond at any time but you will still have to abrade heavily. so why go to the added expence.
We allways bond poly with poly, whypay more.
However if you use epoxy then you will have a problem getting a bond with poly aat a later date.
Sorry guys ,but polyester needs to post cure for a minimum of one month before overcoating with Epoxy.
Polyester to polyester has been used successfully for many years but very careful preperation is required to application area and surrounding laminate however, chemically it is a weaker bond than Epoxy to Polyester this is why some Insurance companies ask for repairs to be carried out with Epoxy resin and mat
To go polyester to existing polyester it needs to be a mechanical "bond" rather than just surface to surface... For example if you are filling a 4" dia hole, you need to chamfer off the hole both inside and outside at a shallow angle going out to probably 8" diameter. to lay up you put an 8" dia piece of mat in first then 7" then 6" then 5" then 4" on each side to build upthe right depth...
The two overlaps inside and ouotside are what give the bond
