Growth on a Swing Mooring over the Winter
Bigplumbs
7 Nov 2015
UK
I was wondering if the amount of growth you might get on a boat that is on a Swing Mooring over the winter months (Say November to March) is much less than over the winter months. This is on the Deben
I am thinking of keeping a 4.2 m Sib on my swing mooring over the winter for a bit of missing about on the river and possibly soom fishing. I was wondering if you could get away without antifouling over the winter.
This would be the boat
Boatworld Range Master 420 - Boatworld UK
sarabande
6 May 2005
BP
My concern would be the boat filling with rain water (if no drain above water level) or being blown over. Anti fouling would be low down on the worry scale.
Unless there's a really beefy securing point at the bow for the mooring, I would add some layers of hypalon to re-inforce the existing one.
Bigplumbs
7 Nov 2015
UK
That boat weighs 75 kg and with Tank and outboard total weight would be 110 kg Plus. I dont think that would blow away. Good point about the water filling up but ways around that
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
I used to keep a gaff cutter on a mooring in Methersgate reach. Sometimes I kept sailing through the winter. She was antifouled, but as you will know the Deben has a party trick of covering antifouling with limescale, and the fouling then grows on top of that. So by the winter months the antifouling wasn’t up to much any longer. She didn’t get much fouler during the winter as I recall.
sailorman
21 May 2003
Here or thertemp ashore
Best t check yr is exclutins first. My olicy didnt cover on a mooring betweecertain datez. M arina no problem
pyrojames
9 Aug 2002
Cambridge
transat2013.blogspot.co.uk
I had an outboard on, plus fuel tank in a 2.80 SIB, along with anchor, oars etc on the Orwell, I was less than pleased when trying to pick up the mooring, to have a rather strong gust pick it all up and dump it upside down. Once the wind really begins to blow, an inflatable is going to take flight!
Bigplumbs
7 Nov 2015
UK
This mow might be the plan:
put rangemaster on the swing mooring. Motor to her in the little sib kept in the dingy park with the 15 hip 2 stroke. Swap over petrol and tank to larger boat and off you go. This way you only risk the 4.2 Rangemaster which cost only £1000 And not your outboard also
Bigplumbs
7 Nov 2015
UK
while all the other answers are useful to think about It was more about how much growth might build up in say 2 months over the winter
Capt Popeye
30 Sep 2011
Dawlish South Devon
Might mention /suggest that if left on a mooring place sealed containers full of water inside the boat to act as Ballast against possible Windage troubles
When going to actually use the boat empty the sealed containers overboard
Gargleblaster
16 Dec 2003
Medway, Gillingham Reach
The slime that builds up to an inch thick seems to occur all year round in East Coast rivers, not just summer. Best protection is lots of use, but even that leaves a bit there. 7 knots is fast for me, so maybe a rib would get more of it off at speed.
Bigplumbs
7 Nov 2015
UK
that is a good idea
Bigplumbs
7 Nov 2015
UK
It is a sib so has a soft hull.
