sebastiannr
Hello,
I have been testing the electrical system on my boat as i believe there may be a minor current leak in the system. Following Calder's classic book i began checking for ground leaks. He suggests that all equipment be switched off, the battery isolator switch be left on, the positive terminal be disconnected, and the voltage checked between the battery post and the terminal: if the meter reads 12v, there is a ground leak. Sure enough my meter reads 12v, and i have identified the starter motor cable as being the cause. But is this not because the starter motor cables completes the circuit as it is bonded to the engine, which is a common ground?
I apologize if the answer is obvious, but thinking about electrics just seems to make my head hurt!
Thanks, seb
Thanks, seb
