pcatterall
Just hauled out after 2 years in the water the last year being in fresh but dirty canal water.
The bottom was fine after a pressure wash, just some bits to re-prime and the antifoul.
The lower sides are now very yellowed ( this is a 1974 boat). I had tried the usual T cut oxalic acid etc to no real avail. I had a rub with some 1000 grit wet and dry and that brought it all up nice and white again.
I could do the whole hull by hand in a couple of days so well worth it.
I could not really see and scratches in the gell coat from the 1000 grit paper but would the panel recommend I follow up the 1000 grit with say 1500 then 2000 or could I just use T cut?
Has T cut an approximate 'value' on the grit scale?
I would follow up the abrasive cleaning with several applications of good wax.
Although I say I could do it by hand would you recommend I invest in a polisher and if so advise on a good inexpensive model?
many thanks
many thanks
