Grit blasting
Windfall
9 Jan 2003
Hants
Not been on the forum for a while but yet another project boat has driven me back. Can anyone recommend a grit blaster on the South Coast? The OH wants me to spend every weekend between now and the spring scraping back 25 years worth of anti-fouling - I'm not so keen as I'd still like to be able to walk upright next summer.
We had our last project blasted about 6 years ago but have lost the contact details so I thought I'd ask your collective wisdom.
Sharon
I had symblast do my boat in the fareham area, good service and saved a huge ammount of work, needed a little sanding and filling after, have you thought what to do with the surface after? Having given it thought I opted just to prime and paint rather than peeling the gel etc
Sharon
see my sig :)
see my sig :)
Server Error in '/' Application.
Could not allocate space for object 'dbo.page_views' in database 'edit116_arccompany' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Could not allocate space for object 'dbo.page_views' in database 'edit116_arccompany' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
I hope your not relying on that signature to advertise your business:(
Source Error:
or:
<configuration>
<system.web>
</system.web>
</configuration>
Stack Trace:
same to day
You will probably find things have changed since you last had this done particularly in ensuing that the environment is protected. You will almost certainly need the yards permission as they will become liable for ensuring that the contamination is removed and there is no run off or leaching. If a specialist contractor does not offer to do this and provide method statements walk away as they are a cowboy.
