TSB240
I am in the process of servicing our trailer before taking it to Brittany later this year.
I have started by removing the 4 Bowden cables which are most problematic if you dunk your trailer regularly.
I found 2 of them were quite stiff (nearly seized but were eased off with WD 40 and with diesel soaking through them overnight.
There was minimal grease in the cup at the wheel end which was dissolved by the WD 40. There was none at the equaliser end .
I was wondering has anybody drilled and fitted grease nipples to the side of the cups?
I could then block off the cup and hope to pressure fill the entire cable with a waterproof grease back up to the equaliser end rather than just filling the cup with grease.
Wheel bearings had no sign of water ingress and I am used to just cleaning and repacking them after any dunking anyhow.
