Granite Worktop
PhilF
18 Jun 2001
In a state
/forums/images/graemlins/frown.gif Someone has managed to chip the leading edge of our granite work surface. what tool should I use to safely sand it down, a file, electric sander or something special - will help to save marriage, Thanks
PhilF
gonfishing
21 Jan 2003
What you need is a cheque book tool
simple really you just get a person onboard that knows about these things and wave said cheque book and broken bit gets mended, new technology, wonderful!!!!
hlb
RIP
Any Pub Lancashire or Wales
It is proper granite. Heres my bloke Jason polishing the stuff. He needs a polishing machine like this, Oh and a bit of skill and lots of water as well!!
whisper
31 Aug 2002
Stratford upon Avon & S.Devon
Not quite sure what you are hoping to do here. If you have knocked a piece (however small) off the front of your worktop then grinding and/or polishing that area will do sod all by way of correcting it. The only way to remove the blemish is to grind down the entire length of the worktop until the chipped area becomes flush with the rest. A lot of work for a small defect - couldn't you fill the chip in with a granite dust/resin mixture and then sand and polish just that bit ?
