GPS
tarik
27 Mar 2004
Broadstairs Kent
SWMBO has bought me an AIS Display unit as a birthday present. Can anyone recommend a cheapish ( Value for money) GPS to link into it. I am not really interested in a chart plotter as such.
Thanks for any replies,
David
Billjratt
9 Sep 2004
Firth of Clyde
Do you actually want a GPS or do you just need lat-long NMEA ?
If the latter, there are USB dongly things available for about £12 or so., and other engine-only devices.
maby
12 Jun 2009
the USB based device is probably not compatible with most AIS displays - they expect serial communications and the USB-serial adaptors sold for laptops are the wrong way round... You can find RS232 GPS receivers up on ebay, but they are getting quite rare these days. There are also little unpackaged GPS modules - mostly from China - that sell at between £20 and £30 and will drive almost anything. hey are probably the best option if you are comfortable with a soldering iron and don't mind encapsulating it in a small plastic box.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
David
Second hand Garmin GPS 45 would do. They're often available on eBay quite cheaply.
maby
12 Jun 2009
Do make sure you can get hold of the required cables before buying any elderly GPSs off ebay for things like this. I picked up an ancient Magellan to provide the positioning data to our DSC radio, then had the devil's own job sourcing the appropriate cables!
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
Elton,
Thanks for that, is there an external lead from the Garmin that can be linked to the AIS?
Cheers
David
I don't know what type of plug you'd need for the AIS end, but this type of lead fits several Garmin devices, including the GPS 45:
If the 9 pin 'D' isn't compatible with the AIS, you should search for a "bare end" 4 pin Garmin type lead. I used to buy from "GPSBitz" but they seem to have disappeared.
You can also buy a lead with an integral cigar lighter connector to power the GPS.
ffiill
5 Sep 2007
So are you saying you can get a USB dongle-gps engines that can pick up GPS signal and feed direct into a laptop? without need for a seperate GPS receiver?
sailorman
21 May 2003
Here or thertemp ashore
i bought a usb GlobalSat BU-353 from amazon.
its a disc about 45 m/m dia on a lead about 1m long, extension leads available if you want to put it on deck
maby
12 Jun 2009
Definitely - I have one from Maplins that cost about £15 and does a pretty good job. It is a GPS receiver without display or controls.
ffiill
5 Sep 2007
Yes just been looking on ebay-I have a non mapping Garmin on my boat and just never got round to wiring it in to my laptop so I can use my Admiralty mapping CD or Seaclear.
This is a far easier option-completely missed out on this one-forget buying old GPs-just plug in one of these with waterproof external aerial.
Mind you only just caught up with Bluetooth!
sailorman
21 May 2003
i have only just open cpn fully loaded & have yet to get the gps hooked up on the netbook
maby
12 Jun 2009
Don't go for the very cheapest - I have come across a few at the very low end that are not very reliable. I would suggest Maplins rather than ebay - the price difference will not be very great and you have the opportunity to return it if it doesn't do what you need.
http://www.maplin.co.uk/usb-gps-dongle-476503
