1 Older charts have different chart datum (OSGB not WSG84)
2 Some surveys are Very old
3 Errors when converting survey data to digitised data
4 combination of all above
the hydrographic office have issued a note on this point, and i believe that it has been picked up by the magazines
the above factors are the cause. the accuracy of charts varies (from memory) from a few meters to 100 or so, with the worst u k areas being n scotland and lands end. in the pacific, it is even worse.
dont forget also that the 5 or 10 meter quoted accuracy of gps post selective availibility is the best achievable figure, with satellites at the optimum position etc. combine this with chart accuracy, and it seems to me that you navigate within 50m by gps alone at your peril.
whats the bets on some plonker in his tupperware tart trap attempting to negotiate a 15 m gap in fog on gps at 20 kn?
Yes
I think you should share that one with the brylcreme team over on the motorboaty flora
The thread is an interesting one - My chartplotter sometimes puts me on Dock Street or in Freeport when the boat is in Fleetwood but there is practically no error for my mooring in Loch Melfort
regards
JS
What care we - tho' white the Minch is,
What care we boys, for wind or weather?
Be careful, there are a number of datums in use, WGS84 being the main one, but the older Admiralty charts use a previous datum. The French use a continental datum. On each chart you will find the datum, for GPS, stated and you have to change your GPS set up to allow for this. Some charts even require to add a correction in addition to this.
Why do I say be careful, in a race off Guernsey, I was close off shore to stay out of the tide and came up just in time to stop a dozy helmsman hitting a rock at speed. The reason was that I had the wrong datum for the chart entered and I was about 150 yards to the South of where I thought I was. I was still shaking two gin and tonics later!
The UKHO advice is not to change the datum within the gps but to leave it set at WGS84 and then to apply any correction quoted on a particular chart for any position plotting on to that chart using data from the gps and that even if the chart datums of two consecutive charts are the same (eg OSGB 1936) to use the correction specific to each particular chart as the corrections do differ......
At this point it is wise to remember that all electronics are merely AIDS to assist navigation and should be used as such when navigating "properly" (whatever that means to you).
It is not only that they may be using different data but also there are errors in each GPS display, errors in chart plotting and, not least of all errors in users plotting the data they are given from GPS.
Using the same data on GPS and a charting system produced a track (in the Baltic) 2 cables inshore for over 1 1/2 miles. That was due to chart (land ploting) errors from an old survey.
Be cautious GPS is only a guide and is not fool proof.
