Scotty_Tradewind
Compared to a 'good' domestic cooker the marine cookers are mostly dreadful.
This has been discussed several times on the forums in the past years and like many, I gave the Spinflo Nelson the compliment of being best value as far as I could make out and the yachting press generally seem over recent years to agree.
I therefore bought my Spinflo Nelson nearly 3 years ago and although we use it little, it does a reasonable job in most areas.
BUT....
possibly to keep the weight down, it is exceptionally tinny and is some areas, poorly designed.
* the top hob surface has joins and areas where dirt easily gets trapped. Most domestic hobs now have a top that is all in one and wraps over at the top edges to just cover the body of the cooker front, sides and back. The spinflo Nelso does not.
* The pan stands are not ideal for very small pots as the gaps between the support are too large and not spaced correctly and can allow the small pots to fall over without the pot holders/supports in place.
* The pot holders do work but are flimsy and are not positive in their adjustment.
* The outside glass of the oven door gets v. hot.
* The oven door has a sprung coathanger type locking strap which is reasonably effective, yet ours sprung open in a seaway.
* There is no built-on lock to stop the cooker gimballing.
* There is no adjustment on the width for the gimbals and I made new arms to give a slightly improved gimballing range and wider to attach in the space I had.
In its favour,
* it does grill toast as well as any other marine cooker I've experienced.
* It's oven appears to heat at a good temperature throughout.
* Its burners light well and the hob ones give a good heat.
* the oven burner has to be lit with ingniter touching the burner right at the back of the oven. There is not push-button igniter on ours for any burner. If you wish to relight the oven burner when the oven is hot then risk of burning your arm on hot surfaces is 'real'.
With mains power and especially if liveaboard, I would strongly recommend buying an induction hob or two.
We bought a couple of the Swan hobs like this.....
https://www.google.co.uk/webhp?sour...2&ie=UTF-8#q=swan+free+standing+induction+hob
We now use one at home and keep one on the boat to reduce the gas use.
My plan in winter of 2013/14 was to make up a gimbled tray with pot holders to put them in the boat instead of the oven.
This was to test out before going to warmer climes. My thought being that I may not want an oven but perhaps induction hobs and microwave.
The Microwave is on the boat but now lays unused in the wardrobe due to me being out voted!
S
BUT....
In its favour,
S
