Going Backwards
Danny_Labrador
13 Oct 2004
Harrogate
When we sailed the last leg of our holiday recently Elba back to mainland Italy the Chart Plotter (Raymarine) decided to show the yacht going backwards !
I first noticed it when the bearing where all reciprocals then I focused on the little boat and it was stern first !.
Tried re-booting but it wouldn’t change it mind. What causes this ?
Probably harks back to the war and the stories of Italian tanks only having reverse gears !
Or else it could be something different entirely!!
I do hope this helps ! !
It gets it heading from the fluxgate compass, was this working/switched on? Other wise it must have been setup incorrectly if it was always out by 180 degrees
I would check the fluxgate then, if the boats heading was a reciprocal then there must be a problem with it. I had a similar problem with one that was buried deep in the boat and in rough seas gave incorrect readings, I found a poor connection was the problem. Yours sounds a bit weird though!
Stubborness normally /forums/images/graemlins/grin.gif
More seriously, if it's now ok, it either saw sense and decided to cooperate, or you'd stowed something metallic near the fluxgate compass that was interfering with it
[/ QUOTE ]Umm, did you have a waypoint in and GOTO'ing? I sometimes set off with the last location still in as a WP and the GPS still thinks it is going to that wp and indicates on the RR display or compass, the heading back to that WP? Just a suggestion...... /forums/images/graemlins/smirk.gif
You might have something there!
I need to recall.
The charter yacht had loads of waypoints in the memory.
Good point !
But then the "boat" piccy would still be aligned with the direction of travel!
Danny
I have seen that problem a couple of times, the heading seeming to dive off somewhere completely at random. It does it for a few minutes and then fixes itself. It's being investigated under warranty at the moment. If I find out what the cause is, I'll let you know.
Pops
Did this occur immediately after passing a waypoint? I have experienced "route reversal" after passing a waypoint when my Raymarine equipment decided I should have been going back from whence I came rather than on to my programmed destination. I noticed this because my VMG to waypoint suddenly became negative but I didn't notice if the boat icon was now going backwards. Logically, on seeing your problem, I guess the plotter was probably showing the boat going backwards if the VMG was negative. I can't answer why this occurred, it happened a couple of times on our 3 week cruise, and I have advised Raymarine procuct support of these occurances. /forums/images/graemlins/confused.gif
P.S. To cure the problem I had to clear the route, reload it and then advance waypoint to the correct leg of the route.
