srah1953
The shackle attaching chain and anchor is a "snag free" one that's tightened using an Allen key. What would be the best glue to use to stop it coming undone?
Blue Loctite is removable easily with tools, red Loctite is more permanent.
I have never tasted either.![]()
When I bought my boat the previous owner had used iron oxide to prevent the shackle from coming undone. This was so effective I had to cut the shackle off! It can be time consuming to apply though so may not be ideal...
There's a product idea.
Instant Rust.
£2.99 for the automotive version, but £17.99 for the Marine Anchor Safe Special pack.
Drill a 1mm hole through the shackle and pin and put in a split pin or wire
Don't try to weld them in with Locktite, rather make them easy to service and remove when you have to, and you eventually will. We do wire tie all our shackles.
