Quandary
I am persevering (foolishly, I know, but this years budget is going to Flexofold and Planar) in my attempt to repair the windlass, gears and bearings seem okay despite the crud around them , though I am not so sure about the electrically operated freefall lever which moves to disconnect the drive shaft, I am hoping to be able to dispense with this.
The motor has not fared so well, The brushes look okay though the commutator is discoloured but there are 4 separate heavy magnet segments around the windings, three of which are sitting tight to the motor case, the fourth is cuddling up to its neighbour despite the magnetic force holding it to the casing and each time I position it it just slides around to close the gap with the next segment.
I presume the three that do not move are glued to the casing and that the glue should be conductive?
A google search reveals specialist conductive glues for electric motors including some by Loctite but these are not marketed to the DIY trade, any suggestions about what might be more readily available to do the job?
Or could I bodge it by putting a couple of small self tappers through the housing and in to the loose magnet?
