Ardenfour
in the quest to reduce the amount of smoke belching from the exhaust last time my engine ran, I've now got the piston out to check the rings. They certainly look ok, but how to check? Is there a typical ring end gap when in the bore? The bore itself is very shiny - should I 'hone' it, if so how do I do it? Also the valves leaked before I dismantled it. The valves and valve seats have a chrome-like finish, does this mean I can't grind them back in as they're a hard material (stellite)?
I've checked the injector under microscope and see crud in the holes, so should I take it for service or is there a way to clean it myself?
The cylinder bore has a layer of carbon above the piston travel, should I clean this off or leave?
