Can you stick it together alright?Does it need abrading/acetone rubbing in to provide a bond?
Yes as Old salt says epoxy sticks fine to polyester but it doesn't work the other way round. Clean well and maybe abrade with an angle grinder and definitely clean with acetone and it'll all go swimmingly well.
Epoxy sticks to cured polyester resin great, a light abrading can only help and a rub with acetone to remove any dust but resin doesn't stick too well to epoxy.
Also don't use fiberglass mat with epoxy as the binder reacts with the epoxy - only use woven roving.
