getting all the oil out of a KAMD300.....
kashurst
10 Oct 2003
Spain
just serviced the engines ready for winter. I still haven't worked out how to get all the old oil out.
I sucked the oil out through the dipstick tube as per Volvo manual but because of the design of the pipe (it has a 90 bend in it) I can't get a flexible pipe right to the bottom of the sump.
What is the magic trick? - can you do it through the turbo oil return pipe?
I'm not aware of one. Getting more than 2/3rds would be considered a success by many. It certainly was by one engineer I discussed this with. Funnily enough, if you take these engines for a service at a Volvo Penta dealer, they are happy to invoice for the full fill capacity.
Perhaps if serviced by someone who knows what they are doing they will take the required amount of oil (about 11 litres IIRC), I know mine would when they were serviced as I have seen them done on more than one occasion. If you dont trust your engineer it’s time to find a new one
No idea if it will get more out but I use a small 12v oil extractor pump but rather than using the thin tube passed into the dip tube, I use the other thicker tube with a plastic end. This fits snuggly an inch or so into the dip stick tube then a bit of leccy tape to make a good seal around the top.
Seems to work well but I guess it depends how low the dip tube is in the sump.
Would like to share with us the method they used to extract the oil. I stuggled to get any more than maybe 7-8 liters.
He used a Pela pump on the dipstick tube and don’t forget to count the contents of filter, engine was hot after a run.
I could be wrong here but think you will find the dipstick tube itself is the oil axtraction tube, ie no need for a thin plastic one down the inside.
I had this same set up on a previous petrol engined boat and could never ever get it to work as it should, so just used a thinner nylon tube down the dipstick hole, took and age and still didnt get all the oil out!
I think current boat has a seperate oil extraction pipe.
My experience with KAD 300 ,s was like the Op only about 8/9 L out of irrc 12 L
We used a Pela pump .
Hot engine and both direct on the dip tube and smaller insert .You have to twiddle the insert a bit around to find the oil .
We never got more than 9 L out .
Tbo I thought it was a bit crappy design wise but with 50/80 hrs per year and an annual change I guess it not too bad .
I would have liked a full sump plug esq change after a complete drain ,but as said only liesure use it seemed to be ok with basically a annual grand dilution 8/9 for 12 as opposed to 11.9 for 12 .
Meanwhile the Germans ( don’t you just love there detail design / engineering ? ) with my MAN s fit a drain pump and pipage .
Key thing is this the pipage is where a sump plug plug would be .They even think out the “ marine “ bit and realise it will be tilted back a bit so make a special sump pan , lower profile with you’ve guessed it the exist at the lowest point in my case the rear as straight shafts ,
So the spec is 32 L and guess what we remove 32 L - Germans :) there’s no moss on there engineers :encouragement:
How do you get the sludge out if you can’t access the lowest point ?
Sort of makes a mockery and defeats somewhat the concept of a pre winter change because the alleged naughty acid parts and more solids bits ,in the sludge are at the base of the sump pan .Or am I missing something .
It’s the last few L that are important.
thanks for the replies. yes the oil was properly warm, yes I used a good electric pump to get it out, and yes seal of hose to dipstick tube was good etc. But as Scubaman said still had 2 - 3 Litres left in and the pump is just sucking air. Whats bugging me is that when I bought the boat the oil was very new and still very clean, so clearly whoever did it knows a way to get a tube right to the bottom of the sump. I shall investigate the crank case breather next time and see if I can take off the oil separator and access the sump through the separator drain tube. It doesn't really matter as I have changed 70%+ of the oil so getting lots of new detergent and corrosion inhibitors in there. Its just a bit disappointing that when you dip the "new" oil its already dirty especially having bought the proper volvo stuff
