Jamesuk
Out of 26 or so bolts one has had to fail after 3 years since the last leak. This time it is just the one bolt. But because the hole is so perfectly drilled I cannot access around the bolt through the hole in the deck to try and seal it.
Anyone familiar with these tracks from Lewmar is that to get access to one thru deck hole you have to remove all the rest of the bolts and wedge up the track to gain access to the one single bolt.
Ok so I am looking for some ideas to fix this mild leak. Frustrating because to do it properly all 26 bolts need to be brought up, that means the microwave has to be pulled out and two lots of perfectly fitted headlining and perhaps a good few days of sunshine to dry out the deck to refit it otherwise we are back to square one; another bolt some where else.
1st idea - Wool and Arbo Mast or " Fill the gap ". ;-)
Cheers in advance.
Cheers in advance.
