Touching Cloth
My genoa sheets are rather tired, and need replacing.
Any recommendations for rope spec and where to purchase?
Thank you.
Thank you.
This is a trick question (no boat description).My genoa sheets are rather tired, and need replacing.
Thank you.
Definitely a cruiser (Moody 34), with soft southerner hands.This is a trick question (no boat description).
Yes, Dyneema will reduce stretch (a few inches in the short distance between the clew and winch), but it can be problematic in clutches (the core can slip inside the cover). Honestly, for a moderately sized boat, you will probably be happiest with a polyester doublebraid like you had before. Any major brand. In the US I would recommend Yale, New England Ropes Sayset (Teufelberger), or Samson XLS.
If you are a racer or performance buff, then Dyneema is for you.
The important thing is a good fit in the winch self-tailor jaws and clutch (if applicable--I don't like puting the Genoa sheet in a clutch).12mm braid on braid will be fine. Liros is probably the most common brand.
