genoa sheets
Gunfleet
1 Jan 2002
Orwell
What's the best way you've seen of attaching genoa sheets? Sewn eye in the sheet end? Bowlines? Snap shackles?
Robin
30 May 2001
high and dry on north island
IMO do not use any kind of shackle including snapshackles, these are very dangerous for anyone working on the foredeck while the sail is set and on a rolled genoa will stain where they touch the sail. Bowlines are simple, work well if the tail is left long enough and come free of charge too.
<hr width=100% size=1><font size=1>Sermons from my pulpit are with tongue firmly in cheek and come with no warranty!</font size=1>
Gunfleet
1 Jan 2002
Orwell
That echoes my own view Robin, but I wondered if someone had come up with a snazzy solution. I seem to remember reading once about 'shackles' made of dyneema
jimi
19 Dec 2001
St Neots
I also stick with bowlines. East too if a bit gets frayed just to cut a bit off the end and retie ... I always get longer than necessary sheets.
Robin
30 May 2001
There ia a means of whipping a loop and a tail together, loop through sail, tail through loop. Don't see the point, like Jimi says you can trim a plain sheet attached with a bowline to get rid of any chafe or to move the wear points like where they pass through blocks, turning blocks or clutches.
10 Sep 2004
Christchurch UK
I use bowlines too - mainly so I can lock the end of the spinny pole through the loop if it's too windy for the kite.
But I always curse when they snag on the shrouds when tacking. Needs some kind of tube to smooth off the lead from sheet to knot?
Geoff
tugboat
1 May 2004
Devon
Never use shackles - sure recipe for headaches or sail damage. I always use bowlines and leave a 6 inch tail for safety. Also it cuts down chafe if you take a round turn through the clew fitting before tying the bowline.
bedouin
I don't like bowlines as I find they tend to catch on the forward lowers when tacking - really looking for a better way that results in a smaller knot
mirabriani
17 Mar 2004
tite stops your nuts falling off
As an alternative to bowlines or shackles, see p 57 Yachting Monthly October
Look for "A hidden clew" made by T-Ring Ltd. Expensive but no doubt will become cheaper in time.
At the back on my mind, I believe I have recently seen another device to do the same job recently. No doubt somebody will pipe up.
Regards Briani
Gunfleet
1 Jan 2002
Orwell
Mine do too - and I would also like to find a smooth solution. You can fit rollers to the forward shrouds, I suppose. I'm not convinced they're any good!
Rob_Webb
20 May 2002
Auckland
The best solution
Saw an article in 'new products' seciton of local NZ boating mag recently that showed new design from one of the sailmakers - it includes a velcro 'pocket' around the eye - allows you to fasten the sheets using small-ish bowlines and then cover them under a neat veclro cover. End result is that it looks like an extension of the sail and has benefit of being completely smooth, no snagging potential etc.
I'll try to find it over weekend and attach a picture and name of sailmaker.
Spose only downside is no loop for whsiker pole I.
Gunfleet
1 Jan 2002
Orwell
Re: The best solution
Thanks.I would be very interested. I only have a spinnaker pole so if I ever stick it on the genoa in a fit of enthusiasm I do uphaul, downhaul and let the sheet run free through the jaws on the end, so I won't miss the loop.
tome
28 Mar 2002
kprick
www.google.co.uk
<cuts down chafe if you take a round turn>
Not possible for us as the clew eye isn't big enough to take 4 sheets. Don't like to tie one sheet through another, prefer both through clew.
Make do with regular inspection - can always end-for-end, cut or replace.
Big genoas in a breeze cause the problem with sheets when tacking IMO. I've recently added a No 3 jib and it's tame as lamb, problem solved.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
I've seen a boat that had a short length of relatively thin 3 strand eye spliced to the clew. The genoa sheet was a single length of rope. The thin rope was double sheet bended (I think) to the middle of the sheet. Looked very neat and much smaller than bowlines. I assume it worked!
<hr width=100% size=1><A target="_blank" HREF=http://www.troppo.co.uk> Follow the Tightwad Sailor</A>
