Gennie Problems
captain tomas
Active Member
12 Oct 2010
Leafy Bucks
Hi everyone ,trust you all enjoyed your Easter.
Over the holiday, I was made aware that my Mastervolt 3.5 generator would not give its rated output.
The unit would give around 7amps but any extra load would show a low voltage warning (204v) and would
cause an automatic shut down.
I wonder if anyone could kindly give me a clue as to a possible remedy.
Also the name and number of a good technician would be appreciated, preferably in the middle Thames area.
Sounds like a Capacitor issue to me,
I can't recommend a technician in the Thames area, It should be a like for like swop.
Anthony
I have a Mastervolt Whisper 4000 which is actually a Paguro 4000 by VTE of Italy, in disguise. Also sold as Westerbeke 3.5 bcdt, and indeed the smaller Fischer Panda is virtually identical too.
When I had problems with it Mastervolt wanted silly money for simple parts, however Advance Yacht Systems of Romsey - Mr Rod Boreham was most helpful.
My unit has the Farymann 15W engine and parts for this part are available from commercial Diesel engine suppliers, e.g. Mitcham Diesels.
PM me if you want the various manuals I have for the Mastervolt and other generic variants of the Whisper 4000 and Farymann Engine. If it is the capacitor RS or similar will be able to supply a suitable unit - make sure the Microfarad rating is the same and the working voltage is at least the same or higher.
Gennie problems
Thank you for your replies, I will investigate .
I'm sure Rod was ex Fisher Panda
I have an Italian genny with a Farymann 18W engine: the capacitor for that was a 20uf plastic case motor run item - £4.64 plus vat plus delivery from Rapid [Pt. No. 10-2950]
John G
Thank you John G,
What was the reason that the capacitor needed replacement, anything similar to mine ?
Chris.
Motor run capacitors do just pack up for no apparent reason, so replacing is the simplest resolve. If it keeps happening then perhaps another issue, e.g. under rated - capacitors need to cope with the AC peak voltage, including an occasional spike, e.g. when switching a heavy appliance off, especially anything with a motor inside, not just the commonly referred to RMS (average) voltage value - 240v RMS has a peak of around 320volts, and spikes could reach over 500 volts.
Thank you John G,
Chris.
Hi Chris,
The problem was a drop in Voltage to less than 150v: received wisdom seems to be that replacing the capacitor solves many "probs" & it is easy to change!
ATB,
John G
Hi John.
Thanks for the reply, could you advise me if your Gennie was giving normal voltage when Off Load
Just trying to amass as much information as possible before crawling in the bilges.
Chris
Hi John.
Chris
Hi Chris,
I believe it was the same with or without load, but that might mean that the load required 230v & didn't take any juice at a low voltage. Obviously, I am not an expert.
John G
Gennie Problem
Hi Chris,
John G
Hi John,
Just to say have replaced capacitor and problem corrected.
Now showing 240v off load and 220v at full load
Thank you for your advice.
Chris.
Good afternoon, i found it on google your issue. So I'm just fresh registered on forum. We do have the same problem and same engine, but we can't find solution yet what for capacitors we need to be replace. I know that it is already 11years ago, but we got this problem just now on our sailing vessel. Until now seems that there is no one who can tell us what kind of capacitors we need. I hope you solved your problem since that time. Could you maybe help us with some advise. Thank you very much in advance SV Spartivento
Good afternoon, i found it on Google your issue. I know ,it is already 11years ago and I hope you solved your problem. We do have same engine and same problem with our generator on our sailing vessel right now. We don't know what kind of capacitors to buy as new one. The old one are broken and it seems like they don't exist any more, so is quite hard to get understand which one are correct one to replace them. Maybe you could give us some advice? will be very glad in advance, SV Spartivento
The information , will be on each individual capacitor , there could be more than one, and be careful they could hold a charge.
