PITCAIRN
Active Member
I have an AC Generator , diesel engine driven (its a Mariner 6000, made by MASE with a Rugerini diesel engine)
It all of a sudden stopped putting out AC power. Whilst the generator was on, there was a sudden grinding of metal and quite a bit of heat and some smoke.
I immediately closed down the diesel.
Just some basic background on this Generator, very simplified..... It consists of a rotor, 2 pole, magnets spinning within the fixed Stator which is made of various copper windings. The Generator is 'Self Excited', in other words it produces its own DC current which is fed into the iron core of the Rotor to get sufficient magnetic flux produced in order to get enough ( 220V ) AC generated in the Stator windings. It is brushless. There is no separate Voltage regulator (like you would find in an Alternator)
After letting everything cool down, I noticed some 'deposit' sitting on the floor underneath the end cap of the generator housing. It looked like a wax like substance.
Anyway, I took off the end cap of the stator housing. There is a bushing, or should be a bushing, located in the centre of the end cap of the housing, into which the spindle of the rotor fits and sits whilst the rotor is spinning (In the manual it is described as a Vullkollan bushing. Apparrentely 'Vulkkollan' is a synthetic substance from which a bushing is made, never heard of it myself)
This bushing was totally trashed, all chewed up.
So I am thinking... as this bushing gave way so the rotor vibrated enough for it to 'jar' and jump and rub against the fixed and stationary Stator. Hence clash of metal and heat. It may be that the Stator and or Rotor are totally trashed, but I want to try to do some tests first and see if I can salvage something.
So what to do. I have tried replacing the capacitor - still no AC.
I have tested the output wires of the Stator for continuity and that is ok , but of course this test would not tell me if there was a short within the windings - maybe an Ohms test would, but what Ohms figure am I looking for?
Next I am going to check and change the diodes which attach to the rotor and are part of the mechanism whereby DC current is produced for Self Exciting.
Lastly, I think I am right in saying that sudden heat and or vibration can cause the iron core of the Rotor to 'loose' its residual magnetism, which it needs in order for it to begin the cycle of producing a Magnetic flux of sufficient size in order to kick in AC generation on the Stator windings...without residual magnetism in the Rotor no Generator would be able to produce AC (well not enough to be of any use, i.e. 110V in each winding so developing 220V).
So how to get back the residual magnetism. This can be done by 'flashing the field' i.e. pumping some DC into the Rotor whilst it is turning, which I believe gets some magnetism back into the iron core of the Rotor. I could not begin to explain the Physics here and its beyond my experience.
Does anyone have any knowledge and experience of doing this - what exactly is the procedure ? And if anyone has any other ideas on what I can do please let me know.
Cheers
Cheers
