dankilb
Yes, that's a very good point, thanks - not something that would have occurred to me otherwise.If you blade smooth it over the dimpled surface there is zero shrinkage. Then put a coat of "the epoxy" over that during the overcoating window and you have you surface that doesn't need sanding with a minimum overcoating window (and no max). Quickest way to a good enough for underwater finish by far.
The specified wet film for Penguard is 150-280 μm - compared to 80-150 μm dry. That's a lot of shrinkage, should I have attempted to use that as the 'fairing' coat over the pox also. I can see how this would undo any effort in 'blading' it on nice and fair in the first place.
Interestingly, studying the Gelshield Plus data sheet throws up a few other points, such as 'Contains no harmful solvents to migrate into the hull and cause reblistering'. I think I'm going to have to overlook this as I can't 'hot film' for the reasons mentioned. Plus quite a few people seem to have used Penguard (or Jotamastic) and - while I do know of at least one who had a breakout of small blisters a few years on, which could have been due to the paint (but were easily sanded back, re-painted, and are now fine) - most seem to have no issues.
I think the decision is made for me, then. I'll use West to fair the pox areas, but forgo any coat of non-solvented epoxy over the entire wetted area.
Yes, we hot coated with West with the 422 additive. There were three of us. One mixing, one rollering and one tipping off. As you said, hard work on your own. Will be interested to know how the Jotun Penguard works out for you as I have an upcoming project I could use it on.
Yup, I should imagine I'll get some assistance at various points, but just cannot rely on it - and it won't be 'skilled', meaning mixing up and roller painting the Penguard is likely to be more productive than the same with mixing, rolling and tipping 'proper' epoxy!
I do otherwise wish I could go down the West route, as the temptation to have whole sections done in a day is obviously great! West's isn't even that expensive, if you go for 30kg, and for what you get (i.e. the ability to do it properly in a day!).
I'll definitely post on here as and how it goes - once the weather and lockdown hopefully align.
