Nina Lucia
We are coming out this weekend for a scrub-off, any recommendations for a good quality gelcoat cutting compound and wax for the top sides? 3M?
I use G10. 3M make equivalent which many get good results with.We are coming out this weekend for a scrub-off, any recommendations for a good quality gelcoat cutting compound and wax for the top sides? 3M?
Thats sounds good!I used the 3m perfect it medium cutting and wax liquid this year on a very heavily oxidised blue hull that was covered in the white powder and it came up really nice, you could see your reflection in it .View attachment 115284
Thanks You!Farecla G3 for major cutting back and G10 for fine cutting. Use a disk polisher and lubricate with a water spray. Use a marine polish with UV protection. More information from my presentation.
https://wiki.westerly-owners.co.uk/images/8/86/Gel_coat_renovation_19May2020.pdf
I ca see more than the photographer's reflection in it. There is a large image of a face in the background. (Or an image of a large face.)I used the 3m perfect it medium cutting and wax liquid this year on a very heavily oxidised blue hull that was covered in the white powder and it came up really nice, you could see your reflection in it .View attachment 115284
3M solid wax smells gorgeous but I haven't seen it around lately.That 3M medium cut and wax is the mutt’s nuts. Did a 34’ and a 30’ inc cabin tops, cockpit etc this year with one bottle and there’s still a little left. And it really works. Small areas, work quickly, top notch.
I also use the International Wax Sealer as the final part of the process after the polishing , keeps the hull very clean and easy to apply.There is obviously a choice of compounds, all of which work, in slightly different ways. Whatever differences exist probably depends as much on the user as the stuff. I use whatever I can get, currently Fareclas G3 with a lambswool pad on a rotary drill, and a housepland spray to wet it, but it is only the HR blue line that needs it.
Sometimes I follow this with Starbrite Colour Restorer polish applied by hand, otherwise an ordinary wax/polish, usually a solid one because it is quicker than faffing around with a bottle. At the end I apply International Wax Sealant, which gives a better shine and lasts a bit longer.
