CarolineSE
New Member
Hi everyone, first time on ybw forum, first time yacht owner..
Problem.. noticed vertical cracks all over the hull. She is standing on land and the cracks are most prominent on the side facing south (exposed to higher temperature and UV, I’m thinking)
Previous owners had her repainted Dark green, professionally, with a two pack paint from akzo nobel. That was about three years ago i think. I dont know if it s epoxy or polyurethane.
I find the cracks or crazing alarmingly deep in some places and hoping it is not a case of delamination!
Can someone kindly shed light over this? Trying to attach photos...
I’m planning to test damp levels and dremmel the cracks to see whats going on underneath.
If it is a case of gelcoat crazing what do you recomend to use as a filler?
International’s watertite epoxy filler?
I see that many are using epoxy resin filler. My boat is from 1970 and made with polyester resin.
Why is predominantly epoxy used and not polyester gelcoat filler? Does anyone know?
Thank you in advance ?
