Currently a lot of boatbuilders offer epoxy primer either as standard or an option before antifouling but it is usually only a single or two coat job to provide a base for the antifouling rather than the five coat job you do when protecting an older boat.
A modern layup is expected to be osmosis resistant however if you are ever going to coat it it will never be easier than before the hull gets wet.
manufactures hull warranties are very limited if you read the finer details and you could find that boats showing signs of osmosis after as little as two to three years are not fully covered.osmosis is a serious problem for sellers of second hand boats surveyors are very heavy handed with their comments on boats with osmosis high moisture content and wicking etc anything ie gel shield which acts as a barrier and slows down the process could save you in the long run i think it is an excellent preventative treatment on a new hull , some manufacturers are offering an epoxy rather than gel coated hull as a rather expensive option, diy gel shield would be a cheaper alternative
That's right, any new products should have to test first and proved that they are safe to use before using. But if there would be any problem the manufacturers will take the responsible.
