MystyBlue2
Hi folks i have a mariner 25hp 2 stroke 1986 (jap model)
I changed waterpump in may and everything seemed fine but today i found it has started to grind in reverse, closer inspection if i select reverse it seems as though the gears are parallel to eachother and wont engage and cause a horrible grinding noise, the shift rod will not drop down it seems to only flex and will only slot into gear if i rotate the prop 1" clockwise or anti clockwise, obviously i cannot do this when i am running out at sea, I have removed the cables to see if the cable is at fault and same issue using my hand on the shift lever so i think i can rule that out. Does this seem like a misalignment issue or maybe gearbox on its way out.
When i droped lower unit to change water pump i made sure it was in reverse before i removed the unit. Neutral and forward gear selects just fine its only on reverse this is happening. I also droped lower unit oil today and i had small metal shavings in oil, (not huge chunks and not alot) but enough to make me want to get this grinding sorted before it turns out to be a disaster.
Hope ive put enough info in and hope it makes sence,
Penny for your thoughts people, cheers
