gasket cemment
cid
18 Apr 2008
portmarnock
What type of gasket cemment would you recommend to use on exhaust elbow were it would come in contact with exhaust gasses and water?.Where can it be got?
Exhaust gasket cement. Specific for the job. Ordinary 'goo' like silicon or Hylomar may not stand up to the heat. Any motor factor can supply.
[/ QUOTE ]Is that the same as assembly paste?
i was looking for a sealant for the exhaust outlet on the eberspacher, they recomend the silicone type, good up to 340 degrees aparenty.
motor factors or ebay, search for exhaust seal
Funny you mention this, I've had the exact same thing on my hands this winter. The normal gasket sealant does not work here I can tell from personal experience /forums/images/graemlins/mad.gif I've now bough some special stuff from Volvo Penta that is supposed to do the trick. It's in a white jar, brownish color. PM me if you need details as the stuff is on the boat at present.
Arno
Thanks for your reply.A motor factors supplied a product called Holts Gum Tar,which would be ok accept water comes in contact with it and it is showing signs of dissolving,so I would like to have the name of the product you used.I was thinking of making up a seal with bosswhite.
.. they recomend the silicone type, good up to 340 degrees aparenty...
Available from decent plumber's merchants as "High Temperature Silicone" for sealing boiler flues, etc. (Stuff I got was reddish-brown.)
Andy
Holt's "Gun Gum" works on exhausts. (Probably not the same Holt as Jack Holt?) Has the added advantages: when you get it on your fingers (and you will) it just peels off when dry; and it is easy to dismantle. Available from Halfords and all good motor factors in tubes and tins.
Gun Gum also is soluble in water so would not be suitable for the exhaust elbow IMHO
