Sans Bateau
And collapse the lid on you if you so much as breathe on it :encouragement:
If its wrongly fitted that is.
Minimal modification, then - replace the string with shockcord and put a hook on the end. Much quicker than hitching it on every time.
I wonder if something like a bonnet prop would be a good idea, simple, mechanical and secure, Oh, also cheap.
I'm thinking of fitting a Gas Strut to my Chart Table Lid; I saw this on eBay: http://www.ebay.co.uk/itm/271071839506
Dimensions of the lid are 400mm x 700mm, hinge along the long side. Weight of lid is 2.4kg.
One of those buckling-spring props would hold it open just as well, without delivering an uppercut to the chin on the way up
[Update]
I've made a mock-up at home, same weight and depth (different width, but irrelevant). The calculators I've seen for various gas struts say that for a "door" of this size, a 120N strut is required. As the lid is being held almost vertical, rather than horizontal, I've found that a strut of 50N is more than enough, I think 30N would do. However the extra capacity will prevent it dropping in choppy conditions.
With 50N it self-opens from about 45°. With the chamber pivot mounted 240mm from the hinge, the piston pivot at 80mm, I get 100° opening, and a 3mm gap when closed.
However, note that I've found a new source of gas struts:
