lesweeks
I'm installing a Plastimo butane cooker and need to make the final connection to orange gas hose. The hose is 8mm internal, which has been fine for other connections with hose-tails etc. but the tubing on the cooker, when measured with a vernier, is 7.5mm and even with two Jubilee type clips fitted I'm not 100% confident - the hose can still slide along the tube. Although it's in a position where it cannot be accidentally snagged I'm still not happy.
Is a 7.5mm OD tube standard? Can I get a compression fitting with a 8mm hose-tail?
Any ideas or suggestions will be welcome.
Les
Les
