Boo2
Hi,
I'm installing a Nelson Spinflo gas cooker in Sunrunner and I need an armoured hose to connect the cooker to the 3/8" gas pipe in the boat.
I emailed Socal and got recommendations to use these two items : armoured hose and 3/8 to 8mm adaptor but I'm not quite sure how that will work out ? Am I right in thinking that the adaptor will attach with a compression fitting to the cooker gas inlet (see attached pic) ? And that the hose will directly connect to the 3/8" gas pipe in the boat without the use of adaptors ? Do they both join with compression fittings (olives) ? Or what ?
Also, am I correct in thinking the T'd off section with the black cap thing at the end end is a test fitting ? If so then can someone tell me how it is used ?
Thanks,
Boo2
Thanks,
Boo2
