Gas cooker piezo ignition retrofit
  • Thread starter Thread starter KAM
  • Start date Start date
Flame failure devices are available separately but, as they cost £15.30 each, it would be uneconomic to fit them.
Supplier, Hamilton gas products.
Not noticed them that cheap. I'll probably have a go but use one of the multi output ones.
Multioutput ones without mains power? Think all the pezo one I have seen are single burner?
I did do a lot of flame failure retro fitting to classic british cooker ovens when the local regs required them for rentals in the Algarve. People didn't want to give up their good quality kit just because there had been a a few problems with inferior ones. i.e. light the oven, shut the door, which blew out the flame. Oven fills with gas, which reaches a top burner, goes BAMM and frightens the clients by flying across the kitchen.
The fitting was not tricky, bit of pipe flaring work and drilling holes, plus mounting the thermocouple in line with the burner.
DW
DW
3 outlet and 6 outlet examples available on ebay for £6.
