paul-essex
The pressure in an lpg bottle is determined by the temperature, at least while there is liquid present. That is why when filling one bottle from another you maintain a small temperature differential, with the donor bottle the warmer of the two. The pressure wont fall until all the liquid has gone if the temperature is maintained.
You mentioned CNG , compressed natural gas, in an earlier post. That is a totally different matter. It is not liquefied. It is simply stored at a much higher pressure than butane or propane.
You also said there is not much difference in the pressures of butane and propane. Infact at 20C the vapour pressure of butane is only about 1.2 bar whereas the vp of propane is about 7.2 bar.
I said that in relation to the camping gaz bottle taking the pressure of propane it would be no problem in my view
