skyflyer
Any recommendations - seems I can pay between £60 and £600. Unfortunateley I find that it isn't always true that you get what you pay for.
The lowest point of the bilge is under the saloon sole plate. The bilge pump (via float switch) keeps the level down to dregs so presumably the sensor is fitted close by there. This would leave a 4ft cable run to where the alarm could be mounted and hot-wired to the battery via the electric panel.
Sounds a simple enough job to me - which probably means I've missed something?
