Garmin HomePort - boring tech question
Ripster
20 Oct 2008
Torbay
Using Garmin Homeport on my PC (windows 7 OS). All works fine using the same maps as per the plotter and able to save and transfer routes and user data from device to device all via an SD card - so far so good. But, to get the PC to "see" my blue chart maps they have to be on SD card media. I have tried to get Homeport to "see" other virtual media (inc creating a new VHD on the system HD which launches with autoplay and appears like any other storage media device) so I don't have to keep a card plugged in, but Homeport will not "see" the map files other than using a card. I cannot find any setting changes in Homeport to have the software look elsewhere to an assigned address. So........ does everyone else just use an SD card for the detail maps (like you would in a plotter) or is there a way of putting these maps on the HD so Homeport sees them?
I'm no expert but from what I remember being told by my son you have to work form the card. I think you can copy the card so as to be able to run one in the plotter while working on the PC on the other (I think!).
Yoda
You're correct, there are no settings in Homeport and the mapsets must be on removable media (SD card, USB stick etc.).
There are utilities around that can create a removable disk using memory or hard disk space though.
There is a further problem because many new USB sticks, e.g. all Sandisk products, now show up as 'local disk' (something to do with Win8 compatability) and Homeport will not see them.
