Garmin GPSMAP750 Data Bridging
superheat6k
10 Jan 2012
South Coast
I have just connected the NMEA0183 data out from The Garmin Port 1 (lo speed) to my Radar repeater. Picking up most data on the repeater (Furuno FMD811) but not depth, (nor time and date).
The depth data is coming in to Port 1 from the Seatalk Tri-data ST50. The Garmin displays the depth data, but doesn't seem to stream the data back out on the same port, nor is it sending its internal time / date data out to the Repeater.
I do have the Data Bridging set to On on the Garmin.
Is this normal or should it bridge the data in on port 1 back out on the same port ?
If so I will have to live with it because Port 2 is used for hi speed AIS in from the VHF.
Should it send its internal Date & Time data out on NMEA0183 ?
Thanka all.
ianj99
11 Nov 2009
UK
You wouldn't normally expect data to be sent back out of the same port - it produces a feedback loop.
So you need a multiplexer such as :
http://www.shipmodul.com/en/index.html
OR according to the manual, bridging only refers to data being bridged from NMEA 0183 to the NMEA 2000 port so is not relevant unless you install a nmea01083 to nmea 2000 adaptor. eg http://www.actisense.com/products/nmea-2000/ngw1.html (~ £100)
All the nmea 0183 data 'from any source' (states the manual) is sent out the nmea 2000 port so it should include the incoming data + all the Garmin generated data. (If the Furuno has a NMEA2000 input then connect it via this instead)
In other words, you are giving the Furuno a NMEA 2000input and connecting it to the Garmin via this. (I am amazed that the Furuno does not have a NMEA 2000 input)
superheat6k
10 Jan 2012
South Coast
The Furuno FMD811 is from the 1980's, so predates NMEA2000.
I will look into a convertor from NMEA2000 to 0183, as it have the 2k backbone already installed and connected to the Garmin, so presumably all the data is sitting there.
ianj99
11 Nov 2009
UK
Blimey - thats more than I paid for the entire NMEA2K backbone. I was expecting around £30 not £90.
Obviously a high rate of Hamble Added Tax !
<20 quid to manufacture, + their profit + distributor and reseller profits = £90
Sounds like an ideal yapp for Angus McD..
