sthurley
Active Member
Hello - Can anyone help?
I have had my GPS 152 connected to my PC using a serial to USB converter. On the GPS side the RS232 plug has a LED, which when connected to the PC glows solid. However recently this LED started blinking, on for approx 3secs off for less than 1 sec. When this happens (and hasn't stopped) the PC goes haywire and nothing works until I unplug the connection (which clearly defeats the purpose!!). From what I can see the GPS settings have not changed and the convertor on the PC has been installed correctly (according to the PC diagnostics it is working OK). The cabling has not been upset. So in short it was working one minute and then simply stopped - note at all times the GPS itself works fine - it just won't play ball with the PC?????
