Garmin GNT 10 NMEA Transceiver
Jokani
21 May 2014
Posted in wanted, but hoping to reach a wider audience here.
If anyone is aware of where I could purchase a used Garmin GNT 10 NMEA Transceiver, I would be grateful if you could point me in the right direction.
TIA
Unfortunately this is a discontinued product now so it's unlikely you will find a new item. Unless anybody has old stock available, you might find something if you keep an eye out on the secondhand market.
Presumably this is to use one of the proprietary Garmin features of the unit, rather than a generic NMEA 2000 multiplexor?
Hi, Yes it is the proprietary Ant+ features that I am after, It sends NMEA2000 data to compatable devices such as watches.
Sounds like you would also like to use a Quatix to control or get information from other brands. I'm also looking for a solution for this, but have not found a resonable one yet, and it seems that the GNT10 was not an ideal solution anyway from what I have read.
Yep, I have a Quatix watch, and a mostly Garmin boat, I have 2 Garmin MFDs that have Ant+ but I was hoping to get a GNT 10 to feed data such as wind through to the watch when the MFDs are switched off.
If you get anywhere, let me know, I will do likewise.
