oceanfroggie
Do the Garmin GHP 20 or GHP 10 Autopilot core packs work with existing raymarine hydraulic pumps?
It has been suggested that Garmin Autopilot core packs will work with other vendors hydraulic pumps. Does anybody know if this is true or if anybody has done this. It would save a lot of installation effort if the hydraulic side can be left alone except for the in line garmin flow sensor. This winter we are planning to replace the existing raymarine network with a garmin one. Also does anybody know if the Garmin autohelm can have a sensitivity/response chart programmed into it (ie different response setting for different speeds). Such should assist low speed steering accuracy. On the existing raymarine autohelm I have to increase the response from 1 to 3 when slowing to displacement speeds or it wanders a bit. Thanks in advance. Noel
