whipper_snapper
I have a Garmin 441s plotter/sounder that sends NMEA 0183 to a Raymarine autopilot. All works well, the autopilot sees the waypoint data from the plotter. Its output is set to "NMEA standard".
I also have an old Garmin GPS152, that I want to receive the same NMEA stream from the plotter - I want it to repeat the depth data.
For reasons I don't understand this does not seem to work. If I simply put the NMEA-in wire of the GPS152 into the NMEA-in plug of the autopilot, where the NMEA-out from the plotter goes in, I would expect it to work. All share a common ground. So I would just be driving 2 'listeners' from one talker which does not seem extreme.
I am wondering if it is a communication protocol issue. The plotter does not say anything about its output except that it is NMEA 0183. The GPS152 is also set to NMEA but with a baud rate of 4800 specified. There seems no way to change the baud rate.
I am also wondering if an NMEA multiplexer might overcome these problems, are they smart enough to cope with various input/output protocols?
Any bright ideas ?
Any bright ideas ?
