Garmin autopilot - opinions?
[33964]
21 Mar 2009
Hello all,
Has anyone used the garmin reactor 40 autopilot? Is it reliable? Any problems?
Thinking of replacing elderly Simrad AP25.
Am after easy wiring and integration, ability to have a second control head, and a remote.
Hello all,
Garmin auto pilots have always been reliable (as have most makes).
Connections between the various components are all plug and play, it will require a NMEA 2000 network (basic parts included in the core pack) to which the CCU and GHC20 controller connect. You can connect more than one GHC20 and a remote is available.
I have a GHP12 which works very well. There are 3 units to interconnect plus the ram. It has a NMEA2000 connection but there is also another cable connecting the heading sensor to the CCU but I don’t know why.
The only difference between the GHP12 and the Reactor 40 is the CCU, the reactor 40 still uses the same GHP12 ECU. You can "upgrade" a GHP12 to a Reactor 40 by replacing the CCU and interconnecting cable.
Thanks Paul. Not needing upgrade yet. But I still don’t understand the random connections when the n2k network is there. Not a problem as all works well as is.
I imagine the CCU and ECU will be exchanging a lot of proprietary data and it's too much data and/or needs to be faster than N2K, but that's just a guess.
  • Like
Reactions: vas
I am assuming (wrongly?) that the Reactor will work with the Lecomble & Schmitt 64240 urt drive unit - am I correct in this?
Provided the following are not exceeded (unlikely i would think):
Maximum sustained motor current: 15A
Maximum instantaneous motor current: 40A
Maximum clutch current: 2.5A
You will also need to add a rudder feedback sensor, if you don't already have one fitted.
There's this one, bad pic sorry.
So which autopilot computer do you have? They have different current-handling capabilities.
No idea, the boat is a long way away, new to me, and I can't find the pic of it :) Must be Simrad from 2006 when she was built, as all the other lectrix.
CR - I fitted one a month or so ago, without any previous autopilot installation experience, it was fairly pain free, including the calibration, although I was aided with advice from Mr Rainbow (doffs hat) . Most of the installation time was spent on installing a rudder sensor, which unless you have a Garmin drive, you will need to do as well I think. So far only one three day trip, so can't comment on long-term reliability, but thus it has performed perfectly.
Looks like it might be a standard 3 wire sensor, in which case it should work. When fitting the Garmin core pack to a non Garmin drive unit, Garmin do a few different conversion cables, so maybe worth an email to their support team, they are usually very helpful.
They are very helpful. I gave them all of my existing set up and they specced the requirements for me. five years on, still all good.
