Garmin Autopilot control head to garmin a/p remote range - how can it be improved?
vas
21 Jun 2011
Volos-Athens
I'm afraid that very much a first world problem but still would be happy to solve it
My Garmin setup includes an Autopilot that is controlled by a single GHC10 on the lower helm.
Being a cheapskate and mainly for design related issues I didn't add a control head on the f/b helm where I only have a GPSMAP4008 and a GMI10.
Now I do have a remote and a month ago also got a Quatix watch which can control the a/p (nice piece of kit btw!).
They both work fine on the lower helm area, but once I get up on the f/b signal is weak and 6/10 it cannot connect. Mind it's a 43 ft mobo effectively distance in straight line from GHC10 to my hand in f/b is circa 2m although there's lots of cabling and wiring in between on the lower helm ceiling.
so was wondering if anyone came across a similar issue and if they managed to solve it. I'm about to open up the GHC10 and try to find it's antenna. Not knowing what Hz/MHz/GHz they communicate I've no idea if adding a length of wire and hanging it behind a side upholstery panel will help or not (no harm trying though..)
ideas?
cheers
V.
thanks for the starter kick!
studying the manual, it is indeed ANT+ which is a 2.4GHz protocol. Now all the ANT+ "antenna"/whatever devices I can find are simple USB sticks (tiny!) that enable PCs to receive ANT+ signals and pass them on to garmin s/w running on the PC mainly for recording training progress, etc.
Seems that what I need is a ANT+ repeater which will be able to pass the signal around and amplify it.
For the time being I've not managed to find anything yet. Hoping for the best :cool:
V.
