Garmin 723 not seeing any NMEA2000 sensors
From post #4 "Thanks for the suggestions and no terminator on the end of the backbone. The t piece is a 2 port "
From post #10 "will try the terminators when at the boat on the weekend "
Seems sure to me.
Good point on the "2 port NMEA connector" though.
@collinsp Can you confirm what you mean here ? Are you saying that you have connected two devices to a T piece ?
Thanks for all the input :-) Here is what I meant by a 2 port connector . . .
Out of curiosity, why the external GPS sensor?
The Garmin 723 has an internal GPS, and I would have thought that it would share this with the NMEA 2000 network (there might be a setting to enable or disable that). It's probably no problem to have two GPS sources on a network, and I don't think this is the cause of your problem - devices should be able to select which they'll use - but this seems redundant, is all.
It was already on the boat so used it and was hoping it would be a redundant source if the GPS723 went down for any reason
And here’s a backbone with terminators in place. And a spare, input. I couldn’t be bothered to disassemble.
A few replies have been made since I started looking for and cropping this image, so it may now be redundant, but an NMEA 2000 network must always have a backbone with a terminator at each end.
